Bradmobile#1 wrote:
I use to have plenty of hot water, and now I have hot water only for a few minutes then it goes cold, my reset switch stays on constantly now. Can someone give me some suggestions on what I can do to fix my problem, please.
What Brand/Model of water heater?
'Reset Switch' On constantly :H
If Atwood....
Red Fault Light means Propane Flame has NOT lit and PROVEN that it lit so 3 attempts and 'Lock out'-----Fault Light
OR the ECO (ENergy Cut Off T-stat ---High Temp T-stat) has OPENED shutting down heating due to HIGH temp (electric or propane)
IF Suburban...
Light 1st comes on when you turn Propane ON then goes out when propane lights off & PROVES it lit....otherwise the light stays on cause propane failed
Hot water for few minutes then COLD----that is cause water is NOT being heated
From your description I am going to say you have a Suburban and the propane is not lighting off/proving it lit cause of light staying on.
Spark electrode is also used to prove flame lit.
Could be dirty///sooted/carbon on it---clean with emery cloth
Could be loose/corroded connection....clean/tighten
Could be loose/corroded ground....assembly mounting screw provides ground
Could be spark gap---too small/too large----s/b 1/8" gap
Could be electrode not engulfed in flame...reposition
Could be cracked ceramic insulator....replace spark electrode
Could be faulty spark electrode....DOES it spark?
