- blkdodgeExplorerThere should be a 1/4" screw at each end of the track..make sure to remove those screw then pull the fabric to the point where it's still in the track. Then pull it back and either have someone hold the loose end or make sure it follows the rest of the fabric back into the track. Then reinstall the keeper screws back in and your done. Pulling the fabric out and then back in is the toughest part.
David - minnowExplorerUse a plastic putty knife instead of the screwdriver.
- SkiSmuggsExplorer
Charley67 wrote:
I'm a little Leary of poking at it with a screwdriver. I'd sure hate to tear it. It was pretty stormy a few nights ago, and I think the wind pulled it out. I can't tell that it has any kind of bead on it to make it stay in. (Thanks, Old Buscuit, for the picture help.
It's broken anyway! - Charley67ExplorerI'm a little Leary of poking at it with a screwdriver. I'd sure hate to tear it. It was pretty stormy a few nights ago, and I think the wind pulled it out. I can't tell that it has any kind of bead on it to make it stay in. (Thanks, Old Buscuit, for the picture help.
- busyguyExplorerMy friend has an Alfa See Ya M/H. The wind blew his awning out of the track. Using a flat bladed screw driver I was able to force the awning back into the track. Opened the awning part way and and got some slack on the material and just went from one end to the other. took awhile but better than taking the awning down. Just take your time and don't damage the awning with the screw driver.
Busyguy - YC_1NomadCheck your threads to be sure they are not rotten,. The fabric may need to be removed and resewn. There are many you tube videos to show how to do it safely. It can be a real hazard if not done carefully. Check out RVGeeks.com for their videos.
- Old-BiscuitExplorer III
Charley67 wrote:
Slide out awning out of track. What has to be done to put it back?
Here's your pic......too many 'img' in brackets - Charley67ExplorerI couldn't get the picture to post. There is a little gutter downspout at each end that is going to have to be removed. Is that just held on by caulk, or is there a screw?
- dbblsExplorerYou are going to have to remove the awning and slide it back in. You need a buddy or two to help.
About Fifth Wheel Group
19,010 PostsLatest Activity: Apr 10, 2025
