laknox
Oct 23, 2023Nomad
wowens79 wrote:
We are looking at going to a 5th wheel from a TT. I keep hearing people talking about being able to turn 90 degrees. I really want to do with the standard B&W hitch in my F-350 with the 6'11" bed.
I realize if I turn too sharp I can damage the truck and camper, but I figure if I can turn a 5ver to 80degrees, that is alot sharper than the probably 45 degrees I can turn my TT. My current TT is 33', and the 5ver we are looking at is 35', so actual towing length will be shorter. Am I missing something?
My '02 2500HD D'max, short bed, 4x4, crew cab, would NOT hit my '04 Komfort 25FSG, a very square front FW. My current '17 KZ had even more room due to the cutaway corners on teh front. I =did= hit my truck with the Komfort when backing up; looking one way and turning the other, and just lost situational awareness. Took out the back glass. I ran a B&W Companion with my Turnover Ball with the Companion set as far forward as it would go. Now, I have a '22 3500HD Denali, SRW, CC, 4x4, and I have my Companion set to the rear as my KZ is only 10.5k GVW, so I have no worries about weight. Again, I can not hit my truck with my FW at full lock, R or L. Because I have a tool box that sticks up about 3" above the bed rail at the front, I do have to watch that if I'm turning sharp on uneven ground. On level ground, the corners of the FW clear the tool box with a couple inches to spare.
To me, if you're in a situation where you need to turn that sharp, you've done something "out of the ordinary" and, usually, you can "back out" of it and take another stab at making the turn. If you simply can't, then try and make sure you've got at least 3 observers, one behind and one on either side. If you don't have them, then you need to move, GOAL (get out and look), make corrections, move a little more, GOAL, repeat as necessary. Any more, I'm not too proud to do this; 40 years ago, I'd've just rammed it through. :-)
Lyle
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 24, 2025
