I have read about manually operating the hydraulic pump with a drill and a 1/4" hex bit. There is an opening on the end of the pump to insert the bit. Has anyone ever done this? If so, does it work...
It will work just like the manual says. However, if you are moving all your slides and your landing gear it will take a long time. You will also probably have to have someone holding the switch to energize the correct solenoids. The time I used mine it took a second battery on my drill just to get the slides in as my landing gear is electric.
