nayther
Feb 09, 2017Explorer
atwowheelguy wrote:
http://www.wiringproducts.com/power-distribution-blocks
Or just mount a terminal block and run your connections from there.
just ordered two of the wiring products versions, should really clean things up. Also saw a solution for the DW's Fusion battery. Ford wants to sell you a full wiring harness if the positive terminal toasts. Received them yesterday, nice quality and will be perfect, I have 4 wires at each terminal and there are 4 connections. Although these are intended for side terminal batteries the hole is 5/16" same as my 6 volt. Won't get to doing it for a week or so but will try to post before/after pics when I'm done.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
