โApr-21-2013 03:19 AM
โApr-30-2013 06:00 AM
โApr-30-2013 05:58 AM
โApr-30-2013 05:39 AM
โApr-26-2013 05:48 PM
Jacking on the U bolt puts all of the trailer weight on a very small area of the axle tube and the axle tube may collapse from this concentrated weight.
As for the trailer aide when a tire is flat the other tire is carrying all the weight on that side of the trailer.
โApr-26-2013 04:38 PM
RCMAN46 wrote:
The spring plate on most new trailers is on top of the axle tube. The U bolt only holds things in place and has no trailer weight on them. Jacking on the U bolt puts all of the trailer weight on a very small area of the axle tube and the axle tube may collapse from this concentrated weight. Lippert states not to jack on the axle or axle parts.
As for the trailer aide when a tire is flat the other tire is carrying all the weight on that side of the trailer. Putting the good tire on the trailer aide does not add any more weight to the good tire.
โApr-26-2013 04:35 PM
dogwood36322 wrote:
I would never use the trailer aide. It is easy to use but why wouldyou want to put the entire load of the side on one tire. Your tire is not rated for that much weight. Jacking under the spring plate will not damage the axle. If it would the spring would damage the axle at that mounting point. Common sense does not prevail when lawyers and some engineers are concerned. The warning and recommendations are to keep people from jacking on the axle tube. My opinion, yours may vary.
โApr-26-2013 01:33 PM
โApr-26-2013 12:37 PM
rhagfo wrote:OK, I'll bite: why not?
Well the concrete will put your life in GREAT DANGER!!!!
NEVER, NEVER use concrete blocks to support anything you are going to crawl under!!!
โApr-26-2013 07:11 AM
โApr-26-2013 06:41 AM
joebedford wrote:
I pinged Lippert about frame jacking my 5th. They said "use a wooden block to protect the frame" and "use a jack rated for 8 to 12 tons". I have a 20 ton bottle jack that I will use to lift all three wheels so I can do my suspension upgrade. I will rest the frame on concrete blocks while I have all the wheels off. Axles can rest on jack stands once the weight is off.
โApr-26-2013 06:10 AM
ependydad wrote:kaydeejay wrote:
NO jacking should be undertaken on a fifth wheel if the front landing gear is down, that is guaranteed to torque the frame. I always jack mine when connected to the truck, which gives it the freedom to rotate at the hitch.
Timely - I have to replace a tire this weekend or next week. Thanks for the tip.
โApr-25-2013 07:37 PM
โApr-25-2013 07:33 PM
kaydeejay wrote:Girevik wrote:This is to discourage the folks who would put the jack under the middle of the axle, which would bend it for sure.
Some do some do not. I owned an 82 Air Stream once and the manual stated to never place jack under axel as it may bend the axel. With the trailer I own now there is no info about where to place the jack, and it has dexter axels.
Jacking under the spring plate at the wheel puts ZERO bending moment on the axle and gets the wheel off the ground with minimum trailer lift.
โApr-25-2013 04:53 PM
