โApr-19-2015 01:53 PM
โApr-21-2015 08:24 PM
Larmoll wrote:
If you have a Mor/Ryde IS, it is a hole different ball game. As to where to jack and how to jack.
โApr-20-2015 09:36 AM
โApr-20-2015 07:18 AM
So my first question is how many hook the truck to the fifth wheel while changing tires and why?
Second question, my last fiver I used a large bottle Jack under the leaf spring between the u-bolts and jacked just till the fire raised off the ground. I know most manufac. say Jack by the frame which is kinda high. I could easily make it work by cutting some 2x6's and screwing them together and set the bottle Jack on that???
โApr-20-2015 05:29 AM
โApr-19-2015 09:38 PM
Old-Biscuit wrote:kaydeejay wrote:Old-Biscuit wrote:If the landing gear is down aren't you concerned about the torque (twist) you are applying to the frame?
..........I do one side at a time (both wheels-----1 jack and then 2 jack stands while gone off to shop) not hooked to truck cause I use it to take tires to shop............
I agree with you about jacking under the spring perch, but I leave the fiver hitched so it can rotate as it is jacked.
Nope!
As stated "I only jack high enough to get tire to clear ground"
Doesn't twist frame at all
โApr-19-2015 08:25 PM
โApr-19-2015 07:22 PM
โApr-19-2015 05:46 PM
โApr-19-2015 03:36 PM
I think the Mfgs say to jack under the frame because it's a flat surface for the jack to mate to whereas the axle is round and they're worried about the jack slipping out from under it. I always jack under the spring hangers like you have and have never had a problem.
Bill
โApr-19-2015 02:58 PM
โApr-19-2015 02:38 PM
โApr-19-2015 02:13 PM
โApr-19-2015 02:12 PM
