Charli's avatar
Charli
Laminated Fibreglass vs Hung Fibreglass
Want to move to a bigger 5er including upgrade of the overall construction quality from our current XLite. For the most part trailer walls seem to be made from laminated fibreglass with either wood or aluminum framing and block foam insulation. Apparently the wall strength comes from the lamination and not as much from the rather sparse framing material.
I came across the Cedar Creek/Silverback from Forest River and they claim their "hung fibreglass" is better construction and eliminates "delamination". Their aluminum studs are 16"OC or less which, according to them, provides better structural integrity than the laminated walls and repairs to the walls are easier and cheaper than laminated.
On the positive side of Lamination the Luan that is laminated to the fibreglass would provide at least some thermal break and the block foam insulation should provide better R value per inch than the batt insulation in the CC. I would also worry about the batts settling after years of bouncing down the road and leaving gaps. Spray foam would be the best solution but probably adds too much to the cost.
What are your thoughts or experience with "hung" vs "laminated".
