You all are missing the fact that the bent leg will most likely not retract. And that to remove the existing leg(s) requires lifting the front-end quite a bit beyond normal.
OP did not state the year of the trailer, however on the 30' statement I assume it has the same single electric motor on the driver's side leg with a connection to the passenger side leg that our Cardinal had.
Get a wrecker via his insurance to move it to a repair shop. They can pick it up and if necessary disconnect the drive to the right leg(1/4 20 bolt) and retract the left one. Drop the right leg extension out if it can be lifted high enough or cut it off.
Chris
