MxDad567's avatar
MxDad567
landing gear
Does anyone make a remote landing switch? My switch is in a horrible spot. So need to replace it with something safer
  • Chalkie wrote:
    Lippert makes a remote system. Everything but the landing gear is on the remote (awning, slides, rear stabilizer). I could move the landing on to the remote, but our switch is conveniently located so I have not bothered. What I don't know is if the system is available as an after market item.
    http://www.lci1.com/images/support/lipsheet/0205.pdf
    My Bighorn came with a Lippert remote that also handles the landing gear. However, the trailer also has a landing gear control on the front outside where it is easy to reach and see at the same time.
  • Put the current switch in a box at the end of 10 feet of #10 4 wire cord. Wire the switch as the OEM and you now have a remote tether cord for $15.
  • My cougar has a remote and it also will raise and lower the landing gear so I know they make one. Or you could wire in a 12vdc remote. Check on Amazon.
  • Lippert makes a remote system. Everything but the landing gear is on the remote (awning, slides, rear stabilizer). I could move the landing on to the remote, but our switch is conveniently located so I have not bothered. What I don't know is if the system is available as an after market item.
  • There was a remote control posted not too long ago that would do what you want but I can't find the link now. Maybe someone else has it
  • Just move your existing switch and put a cover or mirror over the hole.
