5thWheel of Fortune wrote:
We have a 2005 Mobile Suites 36RE that has developed leaky hydraulic lines in the pump and battery compartment. Some are due to loose fittings but also directly through the hoses; the black rubber coating has completely rotted off and you can see seepage. No idea if lines are also leaking back to the slideouts, but we've seen no evidence. My question is how to troubleshoot this and replace any lines as needed. Is dropping the belly of the 5er the only option to trace lines and check for leaks?
Replaced all my hydraulic hoses last year, had one three years ago develop a leak, replaced it and then another last year. At that point decided to replace them all. Very cheap hoses to begin with.
My hoses all have the same fitting both ends, lots of different style fittings. I don't know any other way to check them other then dropping the belly. Big problem is it can develop a leak run down the hose ,and drip several feet from the leak.
I dropped the belly, pulled all the old lines off, cut off a fitting, measured all the lines for length . Sent the fitting to Discount Hydraulic Hose to take all the guess work out of what style of fitting, and a possible mistake by me picking a fitting from their chart. . They made them up, and shipped them to me. Great service, and a much better quality hose.
Discount Hydraulic Hose is located in Philadelphia ,PA 800-535-1302 . Everything can be done on line. I sent them a fitting they verified which one it was ,and I ordered online. I found it much easier, a whole lot less expensive then hauling the lines to a local hydraulic shop.
IMO you would be better off just replacing all those old hoses ,and be done. Dropping the belly is not the most fun thing to do. I have done it twice now, and hopefully replacing all the lines with a quality hose I'm done.
