RedRider16
Oct 13, 2023Explorer
Leaky Plumbing & Winter Living Prep Questions
I figured I would knock out my questions in one topic rather posting multiple threads.
So I have a 86 Terry by Fleetwood that I just started living in a couple of months back since my housing plans fell through when I moved back to my home state and I figured I would live in it through the winter as well since its cheaper than renting a apartment for $1300 a month when all I pay is $280 so I figured I would save the money.
So my shower pan drain is leaking at the drain, Can I just remove the drain and silicone the seal and re-install the drain cover?
Any tips from keeping my water lines from freezing?
My furnace is down for now due to a rats nest but I'll be removing it to fully clean it out but is it alright to run the furnace 24/7 when I re-install it? (Its a Terralab Engineers Inc. Furnace) is there a electric alternative that I can attach to the furnace or replace it to help reduce space heaters and tripping breakers?
I will also be skirting and insulating underneath my camper too and insulating most of my windows and vents.
Any other Tips and Tricks I should know about?
Thank You for any help possible.
