Lifting Fifth Wheel Hitch
Teletech
New to the site so please excuse me if I screw up.
I am trying to locate a Kingpin adapter to help me lift my Hijacker in and out of my f250. I have heard that Demco makes one but I was wondering if anyone else does.
38 REPLIES 38
Learjet
are you looking for this https://www.etrailer.com/Accessories-and-Parts/Demco-RV/DM6100.html
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
agesilaus
I didn't want to imply that I had an objection to hanging the hitch from the kinpin, just that I personally didn't like it.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
bpounds
Make one. Your pin is 2" diameter. A piece of 1-1/2" pipe is 1-7/8" diameter. Use your imagination from there.
Lifting it with the fiver is a good option. Only reason I don't do it is where I park the fiver. Fortunately I have a well designed hitch and can still lift it by myself.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
REWahoo
Old-Biscuit wrote:
The pin box/king pin can easily handle the weight of the hitch hanging from it......when hooked up there is 3000# PLUS King Pin handles full weight of 5vr as it is jerked back/forth
I lift mine in/out with 5th wheel landing gear legs.
Pull pins....raise/drive out
Hitch hangs there until next trip
Backin/lower hitch then manhandle it a little to line up/set it--pin it
Place a padlock on handle latch so handle can not be operated while swing in the wind
^ What he said.
Been doing this for years.
2011 Silverado 2500HD LTZ Duramax 4x4
2007 Jayco Eagle 291RLTS (trade in)
2017 Jayco Eagle HT 27.5RLTS
Old-Biscuit
agesilaus wrote:
Yeah normally you would take to hitch apart into two pieces. Mine only requires pulling a couple of pins to separate the parts. Each piece is much lighter but still no light weight. I cannot imagine getting enough lift height off the king pin to pick the hitch off the ground to a high enough point that you could get the truck bed under it.
Some people do leave the hitch hanging from the kingpin once it is in the bed and just lift it high enough to drive out from under it. I did it one year but all that weight hanging from the 5ver just made me nervous. So I don't anymore.
I do have a couple of 2x8's that can be used to make a ramp into the truck bed where you can push the hitch bottom up the ramp. The top can just be picked up more easily.
newman_fulltime
B&w turnover kingpin adapter plate upside down with a clevis through it works
agesilaus
Superbumper
JKJavelin
I looked around when I got my hitch and didn't find anything else, so I forked out the forty-something dollars for theirs. I have their Ram puck system picture frame with it and yanked the whole thing out at once. Just took it out for the first time the other day after being in the truck for a year and a half.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde AllTrek 4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017-2022 555 Nights
2023- 106 Nights
donn0128
Never heard of one. My Hyjacker come apart into two pieces. I can even at 72 lift it oit myself. If your not capable just but a cheap cable winch for less than 50 dollars from Harbor Freight and a short tow strap. Thats all you need.
