โJun-30-2013 08:58 AM
โJul-01-2013 07:14 AM
robrose1 wrote:
I have 2013 Winnebago lite five that is just shy of 8k. First tow loaded averaged 13.5 with my GMC Duramax.
โJul-01-2013 05:31 AM
allendlung wrote:
I don't understand. 11,000 pounds is the max including people, trailer and contents? Am I missing something?
โJun-30-2013 09:33 PM
allendlung wrote:
My tow capacity is 11,000. I seldom have to worry about my max vehicle.
โJun-30-2013 06:35 PM
โJun-30-2013 05:12 PM
โJun-30-2013 05:05 PM
big bird 2 wrote:
You could go with a Cardinal, which is a step or two above the pack. You did not say how much you want to spend, but you will like the quality and appointments of a Cardinal.
โJun-30-2013 04:59 PM
GPG52! wrote:
You can also look at the KZ 1500 series, however, regardless of which lite weight make or model you chose remember that you are making certain concessions when buying a lite weight. i) wall construction is normally thinner i.e.: 1 1/2" vs. 2" means less insulation and strength. ii) construction studs are based on frame and not the spaced at regular intervals i.e. 16' iii) cabinets are less as the wall integrity is compromised to save weight. iv) awnings are not always anchored in a stud, but, rather only in the skin of your trailer. All are good and functional but you do need to understand the compromises. PS: with a 2500 series I would not be overly concerned with having to get a light weight trailer.
Good luck!
GPG
โJun-30-2013 04:57 PM
rock077 wrote:allendlung wrote:Jim-Linda wrote:
Don't be so concerned about how much you can TOW, be concerned about how much you can CARRY, especially with a 2500.
Jim
I would believe the tow capacity to be 11k. Max vehicle weight is probably 9k, depending on the model year. These are two separate ratings that need to be taken into account.
Look at you door sticker for the empty weight and the max weight (GVWR).
The difference between the two is your max payload.
โJun-30-2013 03:29 PM
Jim
โJun-30-2013 03:24 PM
โJun-30-2013 03:10 PM
Jim
โJun-30-2013 02:12 PM
โJun-30-2013 12:12 PM
โJun-30-2013 11:52 AM
โJun-30-2013 11:39 AM
