manual retraction of slides
mookie
I have a 2006 Sunnybrook 31 BWKS . Not much material came with its purchase. If I ever need to manualy retact the slides I am wondering if anyone knows where I would get access to them. Thanks
Eric Lotreck
11 REPLIES 11
BarneyS
mookie wrote:
The electric motors all work at the moment. I am jsut trying to be prepared in the event that they dont... The underbelly is totally cover in coreplast .Have not found a hole where a crank would go .
The motor is visible right behind the slide out. All Sunnybrooks had their underbellies covered but if you look behind the slideout, you will see the motor and the shaft that connects the two sides together. The part you turn is on the bottom of the motor. You should also have a small crank to turn the motor with. It is black and is about 12-14 inches long and has a square opening in the end to fit the motor shaft.
My trailer also does not have a hole for a crank. You have to slide under the trailer to get to the motor shaft.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
ronharmless
You may have a Schwintek slide, in which case you should read up on them. Clicky
mookie
Eric Lotreck
Campinghoss
On our 2003 Sunnybrook fiver the manual was underneath on the motor or by it. While in New Mexico our slide motor burnt up and I had to manually crank it in and out for the rest of our trip. It was repaired under warranty when we got back home. It would be much easier with a drill though.
Camping Hoss
2017 Open Range 3X 388RKS
MorRyde IS with disc brakes
2017 F-350 6.7 with hips 8'bed
Lucie our fur baby
Lucky 9/15/2007 - 1/30/2023
94-D2
On a hydraulic system there is a manual override mechanism you attach a drill/driver to and run it in. Same for the stabilizers as well. Got big problems if you are there however.
2018 Ram 3500 Crew Cab Laramie 6.7L, Aisin, air ride, Ram puck prep, SuperGlide 20K auto slide.
2018 Bighorn Traveler 4 slide w/Apt.
Itโ€™s not what youโ€™ve done that commands respect, itโ€™s what you do.
Happy Campinโ€™
agesilaus
laknox wrote:
valhalla360 wrote:
We had a 1997 Sunnybrook (mechanical screw system), on the passenger side was a hole and you could insert a crank and wind them in and out.
Better yet, cordless drill with a socket. ๐Ÿ™‚
Lyle
Ditto, you ought to have a mystery crank that goesinto that hole
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
bob213
I read somewhere that they suggest unhooking the battery if you have to manually move the slides. I believe it was about back feeding the circuit. I'm sure someone knows more than me but it might be worth checking out.
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
valhalla360
Nomad III
Nomad III
Lyle
Better was just pushing the button on the wall.
Never had to use the manual method, so not really worth making a version that could be attached to the drill.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
BarneyS
On my trailer, the slide motor is on the bottom rear side of the slide out and can be operated either with the small crank that came with it or a electric drill/socket. It is attached to a long round bar that operates the opposite side gear along with the gear on the rear side.
You have to slide yourself under the trailer to access it.
Although our trailers are different types, I think Sunnybrook was fairly consistent in the use and placement of most things between models and years.
Barney
Not towing now.
laknox
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
valhalla360
Nomad III
Nomad III
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
