Manually Operating Landing Gear
RobWNY
I have a 2019 Forest River Salem Hemisphere 286RL. It has the Venture Electric landing gear. I can't figure out how to extend/retract the landing gear using the crank handle or any other manual method. There's no hole to put the crank handle through to connect to the motor shaft so am I missing something? What would I do if I had a wiring or battery issue and had to raise/lower the 5th wheel in order to hook up?
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
5 REPLIES 5
Toolguy5
On my new Jayco they are independently operated manually. Each motor has an access on the top or bottom to fit a socket wrench on. There is a rubber cap over the bolt. I believe the top is a 3/4 socket and the bottom is 3/8.
Dan & Patty
Miss Pickles the Pomeranian Princess Rainbow Bridge 8/8/2023
2020 GMC 3500 Sierra Denali 6.6 Duramax / Allison tranny
2021 Jayco Eagle 319MLOK
BWRVK 3710 companion
Maddy the Pampered Pom @ Rainbow Bridge 12-3-2013
RAS43
Sounds like some of that "quality build" we are always discussing here.
RobWNY
Thanks sayoung and filrupmark. It wasn't where the propane tanks are but I found it on the opposite side in the battery compartment. The reason I didn't find it sooner was they decided that was a convenient hole to put battery cables through for a second battery so it never dawned on me that was the hole for the hand crank to go through. I think I'll drill out a new hole for the battery cables and leave the crank hole available for what it was intended to be there for.
filrupmark
Did your trailer come with a hand crank ? I Would think that you open the street side propane door to find the manual crank access point.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
sayoung
On my Jayco the crank attach point is in the propane storage bin. No hole on the outside.
