spoon059 wrote:
Cool, thanks for posting! I've got a lot of questions since I saw one installed last!
What size unit is that?
Do you know how many amps it pulls when its running?
Does it cool down your camper faster than the roof AC unit did?
With doors open, does the single head distribute cool air all the way front and back?
With doors closed, does it get stuffy in the bedroom?
Have you tried running the overhead ducted vent fan to move air around?
Finally, what did it cost? Head unit, any installation costs, getting the rack made/mounted.
1. It is a 12000 BTU unit. I don't know the amps but it will run on a 2000 watt generator without any problems.
2. It cools down the RV in about 30 min as where the roof top would never get it to a comfortable temp.
3. Like i said I use a floor fan to move the air around and it will keep the entire RV very cool.
4. With the bedroom door closed I do need to run the bedroom A/C on low if it is very hot outside.
5. I don't have the old A/C so there is no fan for the ducted ceiling. If you do have that it would work nicely.
6. The A/C was about $850.00. Depending on how far the head unit is from the condenser you might need to buy a longer line set. I did the install myself with the help of my son-in-law who is a HVAC tech. The rack was put on before I had this A/C planned. It cost $600.00 at a local welding shop.
I hope this helps. If not ask more questions if needed.
