ependydad wrote:
opnspaces wrote:
My only suggestion is one you've already arrived at. Put some blocks down to lift the whole coach off the ground.
Interesting thought about lifting the whole rig. Definitely could work if you carry enough blocks.
The challenge there is if the rig has a leveling system- you're more likely to run out of stroke on the legs.
And I got chastised for carrying LOTS of treated lumber in my last TT, you should see the stack of lumber I carry now for this very reason. I've had my 6 point levelers error out so many times because of extending legs to the max. Boards under tires are the only way to raise the rig so those steps will come down.
