Cummins12V98 wrote:
laknox wrote:
Just checked Discount Tire, and realized that the Endurance in 225 15" are only available in an E rating. My KZ is placarded for D tires, which gives me a tire load capacity only 360 lbs below my GVW. So, that brings up the question of do I stick with a D rated tire or spend more and go to an E rated tire, which would give me 1,332 lbs OVER my GVW tire capacity (at full psi)? Do I spend $120 more (plus tax) on the Endurance and =deflate= to 65 psi to get the same load rating as a D tire or just buy a D tire, which, IMO is plenty for my fairly light FW? FWIW, I've had good luck with 2 different sets of Carlisles, so that would be my D rated choice.
Lyle
. Get the “E” and use the weight/inflation chart and add 5 psi to chart. I will bet that will be 65psi.
Ok so I have spent the a good part of this weekend researching tires.. being that the nearest Americas Tire is 25 miles away I want to make sure I order the correct tires, went and looked at the tires we have and they are in scary shape (cracks in the sidewalls showing on more than one tire) and we have one more trip for the summer planned at the end of this month. I am going to order 5 tires and have the spare replaced too.
Here are my options for my current 205/75R14 - current tires rating C
Taskmaster Tire Contender TTT868 ST205 /75 R14 100M C1 RBL $46 Each- By far the cheapest which scares me
Hartland ST Radial ST205 /75 R14 100N C1 BSW $77 each- I dont believe I have seen anyone mention this tire as of yet but pricing would indicate it maybe a quality tire?
Carlisle Radial Trail HD ST205 /75 R14 100M C1 BSB- $82 each - I am leaning toward this tire based on others comments but it has a sidewall option that states "Broken Serrated Band" According to goggle this is just the sidewall lettering correct? They also have Carlisle Radial Trail HD ST205 /75 R14 105M D1 BSB about the same price.. but thinking I may stick to C's since my rims are rated for C's
Last are the Goodyear Endurance ST205 /75 R14 105N D1 BSW @ $116 each
Still on the fence about going up to a D rated tire plus now that we are adding a 5th tire...pricey and I wasn't anticipating buying tires until next season so the expense is not budgeted for but I also dont want to cheap out..
We are not full timers, our longest trips typically are 200 miles round trip maybe 3-4 times a year if we are lucky..
Thoughts or recommendations...
