sarahm
Oct 05, 2017Explorer
need new wiring
I need new wiring added to my 5th wheel. Can I hire a Residential Electrician? Or does it need to be Rv Tech?
Beverley&Ken wrote:I see a problem or two with this idea. One is that you may over load the 12v circuit and blow the fuse. So maybe a better solution is to see if there is a spare fuse space in your 12v distribution panel and run a new protected circuit for it. And two is that there may already be a 120V circuit at the location you want your fan if you are using the existing vent hole. This 120v circuit would normally be used for the second AC and have a spot marked in the 120v distribution panel with C/B.
Probably an RV Tech or RV shop that has experience in modifications.
The toilet 12v should not be a problem, just tap into a nearby 12volt line, no special boxes, wiring protection.
The ceiling fan, 120 volt, slightly different story, Power could be obtained by tapping into a 120 receptacle in the bedroom, but concealing (protecting) the wiring up to the location in the ceiling would be much harder, you may have to use a surface mounted wire chase.
The bigger issue would be mounting the 120 v, octagonal electrical box (required to mount a residential ceiling fan), to the RV ceiling would be the biggest problem. A residential electrician, unless he is an RVer, probably wouldn't have a clue on RV construction
Ken
Old-Biscuit wrote:
What is it you have in mind......120V AC, 12V DC, Solar etc
Details will get better responses
New wiring for WHAT?
Seen 'electricians' screw up 30A for RVs and seen 'techs' that didn't have a clue about using a voltmeter
