I recently repacked mine for the first time. On the first side, I used a bottle jack under the frame and a jack stand under an axle U-bolt (my axles are "under slung" so I couldn't use the spring perch). That got both wheels off the ground. My manual says to jack under the frame anyway. By the time I got to the second side, I went ahead and purchased another bottle jack - $30 at Harbor Freight for an 8 ton with plenty of extension. So, on the second side, I stayed under the frame and only used the jack stands as a safety under the U-bolts. Both methods seem fine (it was a good excuse to buy another bottle jack).
Some folks use a "TrailerAid" ramp. I have one, but the spacing between my wheels does not lift one wheel completely without contacting the other.
Be sure to replace your inside seals - but be sure they fit right. I have Dexter 6K pound axles and the Dexter part number associated with the seals did not cross properly to an after market seal (several vendors). Had to get a smaller seal to fit snug so it would not leak grease. Recommendation: try (feel) the seal by hand before you seat it in the back of the hub and assume it to be right; or, go by the real Dexter number stamped on the seal and replace it with original Dexter parts (if that is what yours is).
Amateur Radio WA4GIY
2015 Montana High Country 305RL
2013 RAM 3500 4x4, crew cab, long bed, 6.7 CTD, Aisin trans.
CGVW 20460 Lbs.
