New Cedar Creek tires
ddschuman
We are about to pull the plug on a new 2016 Cedar Creek 36CKTS. Although we have loved our Chaparral, we wanted to upgrade a bit and get something with self leveling and a king size bed. My question is...we have Duravis R250 LT245/75R16 tires on our Chaparral with less than 10k miles on them. The Cedar Creek comes with Westlake ST23580R16*G. We are trading in the Chaparral...should we put ST tires on it and keep the R250s, have the R250s put on new trailer or will these tires even be sufficient in the new trailer since the tires on it are G rated? GVW is 16407. What would you do?
Please no wars. Seriously looking for suggestions as I am not a tire expert. I tried searching Westlake tires and can't seem to find much info. . Thanks!
Escaping the real world in our "home away from home"
2016 Chevrolet 3500 High Country Duramax Dually
33 REPLIES 33
CALandLIN
I recently attended a RV show and looked at some Westlake tires on a couple of Forest River fivers with 7000# GAWR axles. I also took pictures. Here are a few pictures of the LRG steel cased tires.
Pix 1
Pix 2
Pix 3
Me_Again
Me Again wrote:
So much BS about ST tires.
Is the Westlake LRG a steel ply carcass tire? If not, then get GY G614's or Sailun S367's.
To the guy that said 17", no one uses 17" tires on trailers.
17.5" yes!
Chris
I looked at the LRG on a CC 34RL and they are all steel ply. Tread looks like the Sailun. Chris
Me_Again
ACZL wrote:
What's the deal on using ST instead of LT tires?
-- Fed Gov forced the RV industry into using ST tires for weight ratings. Use to use GY G614 LT, but had to go w/ ST's. We've had no problems w/ the Westlake(?) tires we've been using past 3-4 years. If owners want to switch out to LT's they can, but we can't put LT's on at factory. ST tires have a higher weight rating than LT's.
This was the question I asked the CC rep at The Syracuse RV show and his reply. I looked at the side wall of the ST 235/80R16 "E" and it's rated for 3520 lbs @ 80 psi. Did a quick search on Cooper Tires web site at LT 235/85R16 and they came in at 3040 lbs at 80 psi. I forgot, but think all LT 16" are 3040 lbs. Our 5er is still in storage, but I think it's tires are LT245/85R16 and coach has a GVW of 13,800. Apparently no much how one argues, the factory won't put LT tires on. Not sure if dealer would make a deal with a customer on switching them upon purchase of RV.
BS. If a trailer has, 5,200 or 6k axles the manufacturer can install 16" LRE LT's. They just do not want to spend the money for higher quality tires.
ST tires are dirt cheap bought by the train car loads.
LT tires are all position tires, which includes trailer.
High end heavy trailers are coming with 215/75R17.5 all position tires.
In fact trailers can come with P tires providing when they are derated for trailer service.
The real problem is with 7k or derated 7k axles. There is not a 16" LRE LT to cover the required capacity. Chris
topjimmy
For one thing on your 2006 Cedar creek your rims are only rated for 80 P.S.I. most newer big 5er's about 2011 or so on rims are rated for 110 P.S.I tires,on my 2015 Montana 5er I have Geostar G574 14 ply G rated LT tires 235/85r16 rated at 3750 lbs per tire and a speed rating of 80MPH(not that I would ever go that fast) but stock they came with E rated ST Trailer Kings rated at 3400lbs that are just not the right tool for the job on a heavy 5er, Montana and others brands have a option for Goodyear G rated LT G614's but on my 2012 trade in I already had Geostar G574's and had them put them on the new 2015 and the difference is amazing the G rated LT's I bought do not Sag like the lame stock E rated ST's and after 10K miles on them on all kinds of rotten roads around the US not one problem do yourself a favor and get rims that will handle 110PSI Tires and get G rated LT Goodyear G614's or Saliun's or like my Geostar G574's and RELAX!!!!!
2015 Montana 3735MK Legacy,2007 3500HD GMC Dually LBZ Duramax/Allison ,Pacbrake,Firestone Airbags Bullydog Tuner
ACZL
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Coach-man
Fabguy wrote:
In my opinion the country of manufacture has little to do with tire problems.
Most tire problems are caused by age, improper inflation and (more often than not) improper application.
RV manufacturers are quite often installing tires that are simply not up to the task as far as weight ratings go.
Totally disagree! I posted a couple of months ago on my experience with China tires!~ One year old, less than 5K miles and one blew out producing $3K worth of damage to my rig! Do not be fooled, replace those cheap tires with something good, That will be a minor expense, compared to all the other things a bad tire can do! BTW I replaced my tires with the Goodyear G614.
Lantley
ST tires in general are built to meet lesser standards than plain old passenger tires. In the end they maybe OK for general use on utility and boat trailers.
However they are too often problematic when used on lager heavier RV trailers.
Fabguy
Me Again wrote:
"and (more often than not) improper application."
Are you referring to tires that were designed for casual local service that are being installed on most new large trailers that spend extended hours at freeway speeds with poor results?
These tires get inflated weight ratings based on speed restrictions, and often fail within a year or two of service. Chris
I am referring to RV manufacturers attempting to cut corners by installing marginally rated components.
So... Yeah.
The thing is that the end user needs to check for themselves and make educated decisions on what to do about the equipment.
Jeff
2002 GMC Sierra 2500HD 8.1/Allison/4:10/Prodigy brake controler/Pullrite Superglide
Pulling a 2015 Keystone Cougar 280RLS
Me_Again
Fabguy
Jeff
Lantley
The Sailun tire is not your typical Chinese tire. It is built to meet an international accreditation standard that essentially means it is being made to a higher standard.
Member NC Hauler is familiar with the standard because his company must meet the same criteria. He vouched that the standard is legitimate validation that Sailun is building a quality product.
Many forum members have switched to Sailun's tires and all have given positive reviews thus far
buc1980
The Sailun tire are made in China,it stamp on the tire.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
fj12ryder
wls wrote:
where are Sailuns tires made?
They're made in China, and they seem to be a very good tire in spite of that. I've heard of no blow-outs, excessive tire wear, or tread separation, all symptoms of a lot of Chinese made trailer tires.
Howard and Peggy
"Don't Panic"
Fabguy
The website shows that they are "marketed by TBC Brands".
Google search TBC brands and you will see some very familiar brand names.
Jeff
