New Self Adjusting Brakes
Jerry_and_Glori
I'm going to start replacing the brakes on the Everest tomorrow, I thought I had everything but got to thinking about the grease for the wheel bearings. I've got grease but I have no ideal how old it is years I know so I need to buy some before I start. So what kind do you all use No brand loyalty just a good grease for the job.
Thanks Jerry
2015 Dodge 3500 SRW 4x4
2010 Everest 345S
11 REPLIES 11
Jerry_and_Glori
Yes I bought the loaded backing plates as I was going from manual to self adjuster. I got the left hand side done today with some rerouting of the wiring. I did not like the way the wires were just laying on top of the springs.
I've stopped for today it was beer thirty. I'll get started sooner in the morning
and get the Everest out for a test run to check bearing temps and set the shoes to the drum.
Got to get ready to change addresses next month just for the winter.
2010 Everest 345S
theoldwizard1
hornet28 wrote:
Wizard if he did what I consider the right way he bought loaded backing plates. So everything is brand new and no assembly required
gkainz wrote:
I say "ditto" ... I can rebuild drum brakes and have done more than a few. Last brake work on my trailer, I bought loaded backing plates. It may have cost a few dollars more than buying the components, but the convenience and time savings was well worth it.
I forgot how common these are for trailers !
gkainz
My back thanked me as well ... didn't cost me a trip or 3 to the chiropractor afterwards, this time.
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
hornet28
theoldwizard1
I have done a fair number of brake jobs in my life, although never electric brakes on a trailer.
โ€ข Jack the trailer up and PROPERLY support it. Remove tires and brake drums, but leave of side assemble for REFERENCE. There is usually a front and a rear shoe. Don't get the mixed up.
โ€ข Before disassembly, check to see it the the shoes are exactly the same as what you will be taking off. Better to know BEFORE complete disassembly.
โ€ข There are special tools to remove the hold down spring and retainer, but it can be done with a pair of pliers.
โ€ข There are other tools to help remove the return spring, but a GOOD pair of locking needle nose pliers sometime works better.
โ€ข A wire brush, spray brake cleaner and rags are required to clean the backing plate.
โ€ข There are usually 4 points where the shoes slide on the backing plate. These should be lubed with special high temp disc brake grease. You can get a small tube for a couple of bucks.
โ€ข Carefully inspect the wires going to the magnet. If they are chafed, get a new magnet,
Take your time and reference the opposite, still assembled side.
Jerry_and_Glori
I'll get started tomorrow. Doing the complete change out for self adjusters from Southwest Wheel. I'm old and slow so it might take me a couple days because I know I'll find some other things that need attention.
Jerry
2010 Everest 345S
azdryheat
Good bearing grease should be sufficient.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Jerry_and_Glori
Thanks time2roll
2010 Everest 345S
time2roll
Jerry_and_Glori
K Charles wrote:
NLGI grade 1 or 2
You said no brand.
As long as it's good quality and the right rating I'm good. Thanks for the fast reply.
2010 Everest 345S
K_Charles
NLGI grade 1 or 2
You said no brand.
