Nov-05-2014 04:36 PM
Nov-14-2014 06:49 AM
Old-Biscuit wrote:
Backing 5vr doesn't respond as quickly as bumper pull....at first but when 5vr starts to respond it does so faster.
Also 5vr wheels will track inside of trucks wheels when making turns.
Hooking up.....
King pin plate should be lower than hitch plate so when you back in the king pin rides up hitch plate. This prevents 'high hitching' which is where king pin is not captured by hitch jaws which can happen it king pin plate is higher than hitch plate and lowered into hitch.
After hooking up....
Visually verify hitch jaw(s) have closed around king pin and then do a 'pull test'
Pull Test.....
5vr hitched, umbilical cord plugged in, emergency brake cable attached....raise 5vr front landing gear legs until they just lift off ground (5vr full supported by truck)
Then start truck, engage brake controller manual lever fully (wheel chocks should still be in place), place truck in 'drive' and give the 5vr a good tug.
This checks that hitch jaw(s) are locked.
Go to a large parking lot and practice.......backing into parking spots, maneuvering thru turns (right/left), pulling into parking spots 'straight' (no cutting corners-cause those could be curbs or other vehicles)
Have fun!
Which 5vr are you looking at??????
Nov-13-2014 03:30 PM
Nov-09-2014 07:06 PM
Nov-09-2014 07:58 AM
Water-Bug wrote:
I personally avoid hitching and unhitching on a hill. Slight incline of a driveway maybe, but NEVER on a hill.
Nov-09-2014 07:39 AM
Nov-09-2014 02:09 AM
Nov-07-2014 05:57 PM
Nov-06-2014 05:47 PM
Nov-06-2014 07:32 AM
Nov-06-2014 05:40 AM
Nov-05-2014 09:48 PM
Nov-05-2014 08:29 PM
Nov-05-2014 07:49 PM
Nov-05-2014 07:35 PM
Thanks so much. The combined dry weight and capacity is 16500. We've heard that there is a distinct difference in the way you back between the TT and 5th wheel. I guess that skill will need to be worked on. We have also never had a dually, and I've already heard that curbs have been know to jump out and grab that outer wheel.
