โAug-21-2022 04:53 PM
โAug-23-2022 12:49 PM
โAug-23-2022 04:31 AM
โAug-22-2022 06:19 PM
MFL wrote:
A TH usually has a higher pin wt. That is about 25%, where many FWs are closer to 20%. No, that TH pin will not get lighter with toys, as the normal load will be toward the front.
With a FW, nearly all weight will be on your rear axle, so that is the most important rating. The newer GM 2500s have a higher RAWR than earlier years. If you loaded your truck, ready to go, with everything in it, including passengers, and full fuel, checked separate axle wts, you would know what you have left for pin wt, plus about 175 lbs for the hitch.
Let's guess your weighed rear axle is 3K, and your RAWR is 6,600. You will be close to maxed out, with that trailer.
Jerry
โAug-22-2022 06:48 AM
ESDA wrote:
Is there a safe way to increase the payload capacity of the truck, like adding bigger springs or anything?
โAug-22-2022 06:19 AM
ESDA wrote:
My truck has RGAWR of 6600, GCWR of 27,500 and a curb weight of 8,302. Per the trailer specs it has a hitch weight of 3,175 and a dry weight of 12,650. I have not yet bought the trailer so I cannot take it to a scale yet. Trying to figure out if this will be too much hitch weight for the truck. I assume that since it is a toy hauler, if loaded in the back the hitch weight would go down a bit. However, we probably would not always have the back fully loaded.
โAug-22-2022 04:40 AM
โAug-21-2022 07:28 PM
โAug-21-2022 07:16 PM
โAug-21-2022 05:59 PM
โAug-21-2022 05:57 PM
โAug-21-2022 05:55 PM
โAug-21-2022 05:48 PM
