โFeb-10-2017 03:47 PM
โFeb-11-2017 04:32 PM
โFeb-11-2017 03:29 PM
โFeb-11-2017 03:02 PM
shadows4 wrote:
Oilcan, your rear axle should be rated to 6084 lbs. The lower rating on the door sticker is probably due to the tires that came on the truck. Here is a link that you can put your vehicle vin in and it will give you a spec sheet on your vehicle. Just follow the link and select the vehicle tab to enter your vin.
I think you will be fine on your weights. Good luck, John
โFeb-11-2017 02:19 PM
โFeb-11-2017 01:44 PM
โFeb-11-2017 12:40 PM
oilcan1001 wrote:
I cant get you a pic of my calculator stats, but here are my numbers and those who don't understand my numbers can plug them into the calc.
Also, I'm using my vehicle tag vs a VIN search for Specs (the VIN search gave me a 6830# RAWR which is 1860# more than the tag in door jamb
Front GAWR 4250
Rear GAWR 4970
GVWR 8800
GCWR 20000
On CAT scale with trailer attached (empty):
Front axle 4280
Rear Axle 5000
Trailer Axle 6420
CAT scale truck only
Front Axle 4160
Rear Axle 2860
Hitch GTWR 24000
Trailer GVWR 14000
Truck tires are new and rated at 3415# per tire
Hope this answers the questions
โFeb-11-2017 11:44 AM
โFeb-11-2017 11:40 AM
โFeb-11-2017 10:43 AM
โFeb-11-2017 10:24 AM
โFeb-11-2017 09:17 AM
shadows4 wrote:oilcan1001 wrote:
I'm only 30lbs over RAWR
400 lbs over GVWR
1830lbs under tire ratings.
This is with an empty trailer.
I'm hoping it will get under specs when I load the garage (behind rear axle).
We'll see Sunday when I weigh fully loaded
Oilcan, this may help in your calculations. Here.
โFeb-11-2017 08:34 AM
400 lbs over GVWR
โFeb-11-2017 08:09 AM
โFeb-11-2017 07:48 AM
