Kohana, I have the BFG Rugged Trail tires that are 10 ply. They came on the truck. After about 74000 miles, I decided to put another set on as the first ones did serve me well. These probably have a slightly different tread pattern from the All Terrain but thought you might be able to compare since they are both BFG.
I had put a new set of the BFG TA Commercials on the 5er and due to a recall about 2 months after I put them on, I ended up with a set of Michelin XPS for the trailer. It helped that Michelin owns BFG. Tires on the truck are 10 ply and I think the same on the trailer. Good Luck shopping and Happy Camping.
dan218b@tds.netDan and Lori Branson
Anna 1 and Lily( The new one)
Sarah-7/16 and Beau at the Rainbow bridge
2015 Ford SD350 Crew Cab Power Stroke
2009 Open Range 337RLS
Old Fella Rally Member
RV.Net Ohio Rally Member
