shadoow
I am talking about the outside fans that push air up pass the condensor fins.
If you look at section 4 of the service manual it will show you diagrams of how it is setup. I found my Thermostatic switch was mounted over a slot in the condensor fins. If your fridge is in a slide out and vented out to the side, look in the opening and you will see the condensor fins, look to were they have mounted a switch to the fins, mine was about 4" in over a slot that made the switch useless. In hot weather, the fans would only run occasionally and I had trouble maintaining fridge temperatures. Now that I have moved the switch
it works a lot better.
Now if I could figure out how the board controls the warming of the fins to melt the frost I would be happy, I think the electrical board is giving up.
