davidkerry's avatar
davidkerry
Optima battery replacement or charging system
Hi folks, my toy hauler is a 2004 WW FS 22 with an inboard Onan generator , the generator starts right up and runs great...Tow vehicle is an 09 3500HD duramax silverado with the factory pin connections
my problem is blue top optima batteries are not holding a charge anymore ...
or not getting a charge
typical case....after a 3 hour drive from home to desert ..all the battery status lights are green but after only 30
minutes with just the cabin lights on , the green is now yellow and red is about an hour away.
ill run the generator for 30 minutes , the green lights come back on, but drops again within 30 minutes
the batteries were bought new in 2009, so 5 years old , toy hauler spends a lot of cold nights in the desert camping and a lot of hot days sitting in storage in OC.
Are the batteries just worn out/..OR ...is my charging system not working ? ...or both?
I have voltmeter , can anyone explain how to check? or is there a website?
Are the cheaper RV batteries from autozone any good? or better to replace with the $200.00 (or more) optimas?
any advice , information greatly appreciated! THANK YOU!!
