pot lights
dmaxing
I have a carriage cameo f35sb3 it has 2 pot lights in the kitchen area they have a chrome ring with the lens in the middle how do I change the bulb, thanks
6 REPLIES 6
hawkhill
BTW - the bulbs in the silver ring fixtures are 20 Watts whereas the bulbs in the plain frosted glass (no rim) fixtures are 10 Watts.
2015 RAM 3500 dually Deep Cherry Red Crystal 6.7 Cummins Aisin 6-Speed
2008 Carriage Cameo F35SB
Jeff "Loving DH"
Smokey & Purrshing, Our Ragdolls
Gordie, Springer Spaniel
True Blue, Aussie
hawkhill
We have the same unit. You need to hold the chrome ring fixed. Don't pull it down too far as the spring tensioners will pop. You have to kind of push up on the frosted glass lense and twist it. I had a hard time getting a good grip on the lense and ended up using one of those rubber can opener grip pads to get enough friction on the glass to twist it.
Jeff "Loving DH"
True Blue, Aussie
DutchmenSport
Absolutely, 1/4 turn (counter clockwise on the ring as you look at them from the front, or from the floor up)
donn0128
Try twisting CCW on the chrome ring. The lights I have in my kitchen are twist lock. Quarter turn is enough.
2oldman
For a sec there I thought we were talking about thousand-watt halogens.
Mandalay_Parr
Probably pull down on the chrome rings.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
