Check the terminals on the converter chassis. They should be labeled (+) and (-), regardless of wire color.
You could also plug it in to AC and check the output terminals with a VOM.
Having said all that, it is very unlikely that the white wire is not the negative.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
