- RCMAN46ExplorerWhich Prodigy controller do you have? What is the error the prodigy giving?
- eHoeflerExplorer IIIf this is your first outing this year, you need to burnish off the rust in the drums where the magnet contacts the drums. While driving out I manually apply the brakes for the first 100 yards or so. The brakes will start to grab as they should
- ACZLExplorerGo to "Towing" section and read up on posts under the "Intermittent Brakes" topic. Think you'll find your answer there.
- cmeadeExplorerFirst step is to pull the breakaway and determine if the trailer brakes are working correctly and then proceed with your troubleshooting. On loose gravel slowly drag the 5ver and see which wheels don't lock up and start there.
- SARGUYExplorerI would check for a bad ground or a loose wire somewhere in the system.
- FabguyExplorerAll 4 brakes have magnets.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
