pull rite-super glide
24fb_freedom
I bought a pullrite superglide hitch (the 2900 model) and in the manual it states you can use a lock to secure the handle when in the locked towing position but I can't seem to find a lock that will work on this model because of the design of the steel around it, what do you guy's use on this hitch to secure the handle from coming open when traveling?
thanks in advance.
17 REPLIES 17
azrving
I have a 2900 and there is no room around the handle to install a padlock. I made a U shaped bracket that prevents the handle from raising up enough and coming out. I had to drill a hole in the U bracket and the lip of the frame for the padlock.
Let_s_Travel
Would like the exact wording from the manual on that to help. I've never seen a lock other than the one on the handle. I think you may be reading that wrong? The handle drops and locks in place. You have to lift it and pull to release. Maybe you have a new design I'm not aware of??
