I too 2nd CumminsV12 on going w/ the B&W. He sold me on them 3 years ago. I started off w/a Reese slider back in '03 w/ a short box Ford. Used it maybe 2x while I owned it. Made a deal w/ dealer on a used Reese 16K 4-way pivot head non slider. When we got a new '15 Ford, switched the Reese 16K to it. The Reese was ok for trailer we had and I really liked the pivot head due to a awkward angle I was in w/ the old non pivot Reese and trying to hook-un-hook. When we upgraded to new coach in '17, in my mind the Reese 16K would be taxed although probly still within it's limits------I just didn't feel comfy w/ it. So before we went to p/u the new coach, bought a B&W Patriot 18K non slider (truck still a short box). Oh, Reese rails were used on the '15. The '15 was a SRW F350 and did a good job towing the new coach. Really liked how you could switch the "A" arms around to move Pin location as well as height. Bought a DRW F350 in '18 (off the lot no pucks) and this time used B&W rails. Holy schitt the B&W rails are BEEFY!!!! Compared to the Reese rails and Reese hitch, B&W is HEAVY DUTY all the way around!!! Never had a problem w/ hooking/unhooking and no chucking/jerking at all. Personal preference here, but I have the 5th Airborne pin box and CumminsV12 has the Trail Air, both achieve the same results but go about it in different ways.
As for a slider/non slider hitch, most newer RV's have cut corners so one can make a sharp turn w/a short box w/o hitting back window. Should you have a older RV w/o cut corners, making a sharp turn is tricky w/o a slider. My take is, if your in that tight of a turn, then put it in drive to straighten out and the proceed. Yes you still have to watch how close you are to window BUT if you take your time, there is no need to slide the hitch. I've always done that and no problems-----hence only using my old slider 2x in several years. I wouldn't go back to a slider if a got another short box.
As I said above, Cummins V12 sold me on the B&W and I will stand right beside him promoting it. This past winter I bought a B&W adjustable turnover receiver for my snowmobile/landscape trailers and Holy Moly it's made/built like a rock!!!! So if you end up w/ a new hitch and rails, I'd strongly suggest going w/ B&W.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
