Crodad
May 31, 2017Explorer
Rear Kitchen
I have a Silverback 31RK(rear kitchen). I'm having things break in the cabinets, even the glass plate in the microwave broke. I ordered a Trailaire pinbox that is on backorder and I'm starting to wond...
rhagfo wrote:donn0128 wrote:
Does your SB have shocks on the axles? If not add them.ACZL wrote:
Trailer susp ugrade. Independant suspension, Equa-flex, Mor-Ryde. I think shocks come w/ CC's (at least they used to). IMO, don't think a air ride pin box will help you in keeping rear bounce down.
Pin box is going to do S*** for your breakage issues, might make your ride better, but the 5er is still back there beating its self to death!!
See the two post above, level the 5er so it isn't trying to hop over bumps. SHOCKS!!! this will make the best improvement, and wet bolts. If it isn't current set up for shocks Lippert makes a kit with shocks (made in China) well the brackets are good!! :S I got about two years out of the shocks, just replaced with Monroe 555001's and we are back to a very smooth ride.
This is with a standard pin box.
Keep in mind too many go for the "quick Fix" which really isn't a fix at all it just mask the issues the 5er has.
One really needs to fix the 5er, then think about the ride in the TV, because once the 5er is fixed, the TV ride will be much better also.
