cummins2014
Sep 12, 2016Explorer
d-mac1 wrote:
I had Firestones added to my Ram 2500 when I had the B&W Turnover Ball installed. They are setup to be filled independently and I do so via Schraeder valves and a bicycle floor pump.
Perfect solution.
I suggest not using a T to connect them in the event that some day you want to carry something that has considerably more weight on one side.
I used Air Lift bags on my 4Runner and the air line connections continually blow off. They suck IMHO.
I think you have point on the weight thing, but as far weight distribution, getting considerably more weight on one side is pretty remote, hauling dirt, gravel or building materials. I like filling both at the same time. Now if I had a camper on there then I would want the independent air fill.
I have run AirLift connections on two different 1 ton trucks with no issues, maybe wondering if you didn't get the airlines pushed in all the way or not cut properly.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
