Stefonius wrote:
DiskDoctr wrote:
I didn't see anyone post the purpose of a red (1st/single stage) regulator, though some hinted at the workings.
I wonder if the OP's rig came with the "Generator Prep" package. The red regulator is used to supply propane to a built-in LP genset, and the regulator would be present in the system if the unit was prepped for a generator by the factory.
No I've had a generator in all my 5ers and they run off regulated gas downstream of the changeover regulator. The red regulator is on the LP tank distal from the automatic changeover regulator. Gas downstream of the red regulator goes directly into the changeover regulator.
