Old-Biscuit wrote:
Mile High wrote:
Actually it provides back pressure on the on the cylinder furthest from the main regulator, to prevent the safety valve from slamming shut if you open it too fast. Didn't used to be an issue until the design of the cylinders changed to the high flow safety shutoff.
They are cheap regulators, and are a hazard greater than what they are trying to overcome - 2 of mine have leaked. I just remove them altogether.
The excess flow shut-off is in the hose......not in propane cylinder.
Propane cylinder does have a spring loaded valve that closes when hose is disconnected. Can not get flow from cylinder without hose attached.
Yes there is ball check in the hose, and there is an OPD, but there is also an excess flow check valve in the cylinder valve:
Check Valve - The check valve is designed to gauge the pressure of the gas as it leaves the propane cylinder. Because the gas grill should have all valves in the "off" position when the gas is turned on the pressure stops at the valve and is re-checked by the valve at the tank. If there is a leak or if the grill control valves are in the "on" position pressure is released and the pressure checked at the valve is different. When this happens the check valve is designed to stop gas flow through the valve. The problem with the check valve is that it is very sensitive and when a tank is full, with the additional pressure of the OPD float pushing on the liquid, the gas can push through the check valve so strongly it checks the check valve by mistake. This happens frequently.
