Y-Guy
Aug 06, 2014Moderator
We had a table in our Raptor, it appeared to be screwed down the the floor. My guess is that with the side extended you can run a bolt through the leg of the table and through the slide out floor. I'd think there is enough room for a fender washer and nut to secure the table. However you'll need to explore your setup Our chairs had a simple hook located on either side of the chairs that had a strap that hooked in place and was then tightened by pulling on the strap. Worked fine, unless we forgot to secure the chairs. ;)
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
