Gordon_R's avatar
Gordon_R
Removing and Re-Installing B&W Companion Hitch
I've been pouring over the written instructions, looked online - and searched this site. I need to hear from folks who have had this hitch for a while as I am a new user of this hitch.
Recently, I had to take the base and saddle out of the truck bed. Followed the instructions and pulled the pin in the wheel well and rotated the handle to the left. Removed the saddle - no problem.
Instructions said to loosen the bolt on the top of the base unit to withdraw the pin and base. Done No problem.
Now. I have to put it back in. Reverse process. Wheel well pin slid back into the pin that goes through the truck bed. Tightened the center bolt on the top of the base unit to 60 pounds using a torque wrench (per the label next to the bolt).
I noted that when it was initially installed, no grease was placed on the center pin base plate where the pin comes in contact with it. I did that. Also, they didn't use any lithium grease on the nylon caps. Will be picking some up today.
Anything else I need to do? Looks and feels right, but, I want experienced input before I go and hitch the trailer to it.
Thanks.
