jackpam's avatar
jackpam
repairing leaks
Has anyone out there ever used flex steel successfully for plugging leaks and does it work on rubber roofs?
  • I agree with previous. Do a search and use what they recommend for rubber roof repair. I hit a tree awhile back and they could not put a new roof on for about 2 months. Dealer put a big patch on that was designed to repair the rubber roofs. I looked very good, but not a permanent patch. However the patch would have lasted a long time. Go with recommended product.
  • I don't know how it will work with the rubber on the roof. Many products will actually dissolve the rubber. Why not stick with the tried and true methods?
    B.O.
  • Get the repair kit for rubber roofs and do it right e.g. http://www.pplmotorhomes.com/parts/rv-roofs/38-1416.htm
  • RoyB's avatar
    RoyB
    I am guessing that the FLEX SEAL you are referring to is the spray on rubber coating... I have never use any of these type of products...
    AMAZON has some reviews on using this product both PRO and CON...
    FLEX SEAL COMMENTS
    Roy Ken
