Replacement axle question.
shadows4
Hey guys, I have a question some of you might be able to answer.
I had a bent axle replaced by a local company. The trailer tows fine and braking is good. I had them replace the springs and brakes all around. So the only thing original is the front axle. I thought it looked a little off but told myself it was all in my head.
Got under the trailer today and the new axle is 1/2 inch narrower than the original. You can see it on the drivers side. The curb side is lined up like it should be. Is this going to be a problem down the road? Thanks.
2016 4X4 F350,CC,SB,Lariat,6.7L diesel,
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
15 REPLIES 15
TenOC
shadows4 wrote:
H
Diameter or length????
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
