- cummins2014Explorer
Cummins12V98 wrote:
cummins2014, to be polite he could use a lesson in punctuation.
I don’t proclaim to be an expert on the subject but it simply makes no sense.
It made no sense to me either . :) - TxGearheadExplorer II
buc1980 wrote:
For sure Sailun made in Vietnam are trouble but then what tire for heavy trailers Goodyear 614 way to expensive.
I think it's a **** shoot. Goodyear, Sailun, Hercules, close your eyes and pick one.
We just got home from on the road...NASCAR at Kansas City and a few days in the Ozarks. We were parked/camped next to a big Newmar diesel that was towing a matching "stacker" type trailer. He had a mix of Goodyear and Sailun on the 3 trailer axles. He didn't like either of them, citing unusual wear patterns. Probably a good chance it was trailer axle issues. - TxGearheadExplorer II
JIMNLIN wrote:
TxGearhead wrote:
Sailun like other tire mfg has many different tire types...S637 is just one of them.
I had a blowout on a Sailun on our 5th. I replaced with Herculles. So far great.
I have Carlisle on a dual axle boat trailer and 2 utility trailers no issues. Had the Carlisles on a Montana 5th wheel no issues.
Even the S637 has 16"/17.5"/19.5" sizes so its important in reporting which Sailun size/load range product had a blowout.
Several years back one one member posted he had a Michelin XPS Rib blowout. However later we learned the tire was 6 years old and had 30k+ miles on it. But more importantly he ran the tire till it shredded down to the rim. No blow out ...just a run flat.
Some folks got upset about finally a XPS Rib blowout and there no different than a ST tire.
Makes a big difference when all the facts come out.
Last night I remembered I kept the original Sailun spare since it had less than 30 miles on it. I checked the sidewall and it has a date code code of 4316 and made in China. That would make it less than 4 years old when it blew.
The unknown variable is that we are the second owners, so no telling how the tires were maintained. I watch pressures pretty close and use a TST tire monitor. - buc1980ExplorerFor sure Sailun made in Vietnam are trouble but then what tire for heavy trailers Goodyear 614 way to expensive.
- Cummins12V98Explorer IIIcummins2014, to be polite he could use a lesson in punctuation.
I don’t proclaim to be an expert on the subject but it simply makes no sense. - cummins2014ExplorerYou are saying you bought F rated Sailuns, I am pretty sure they are G rated @ 110 psi .
You said , I quote " Mine were built in not China ". Whats that mean were they built in China , or were they built elsewhere ?? - bluefishgaryExplorerI also have the sailun tires,they replaced,The goodyear endurance.
I have a 3 axle toy hauler 18,000 lbs
Mine were built in not China, they were built end of January 2021. They are 16"
And F rated @ at 110 lbs. I run only
90 psi as that's more than enough for my load.so far so good . Total miles so far
6,000 miles. They do ride harder than the goodyear but a much heavier tire. - TxGearheadExplorer II
It was a S637 215/75/17.5 LR H. The blowout happened in August 2020. I replaced the Sailuns in January 2021. The trailer is a 2018 Landmark built in 2017. I don't remember the tire build date or its country of origin. I do remember the tire build date was appropriate for the trailer build date. - GaryUTExplorer III would look at the Goodyear G614 it is a load range G tire.
- JIMNLINExplorer III
About Fifth Wheel Group
19,010 PostsLatest Activity: Mar 31, 2025
