mksmitty1960
Aug 25, 2018Explorer
Residential Refrig, not enough power
I have a residential refrigerator in my fifth wheel and running out of electricity in about two days. Currently running 2 six volts and have a 200 watt solar panel putting out about 8.7 Amps. I am considering the following upgrades, 4 Six volt batteries, adding a second solar panel and the possibility of adding a secondary battery charger to a 20 or 30 amp. I also run a generator about 3 to 4 hrs a day. In regards to adding a second battery charger, do you need to disconnect the original factory charger? Would this work?
Thanks, Mike
❚ Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
Thanks, Mike
- "Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post in the RV Forum which corresponds to the subject of your topic. Thank-you!"
