Roof leak?
MJO21
I had a roof leak over the winter. I found two spots where water came in. I took off the old caulk and recaulked it. I have not had any water in the camper since.
However, this has been happening on the inside ever since.
I talked to a local rv center yesterday he said there is water trapped in the ceiling.
What do you think? Is there water trapped in the ceiling?
They said I have to take the inside ceiling out and out in dehumidifiers and dry out and reinstall?
Thoughts?
5 REPLIES 5
Aridon
Those antenna can have an area between where it cranks up and holding bracket on the roof where water can leak. There is a rubber condom looking thing that covers where the wire enters the rv and that area cash be problem with leaks. Some sealant under that rubber piece solves that if that is where it's coming from.
2019 Grand Design Momentum 395
2018 Ram 3500 DRW 4.10
2014.5 DRV Atlanta (sold)
2008 Newmar 4330 (Modified) Sold
ksg5000
Drying out the rig when you have a leak makes sense to me - as others have said it's likely your going to have to replace the interior lining to make it look new. I believe that interior antennae crankshaft shown in the pic should be easy to remove - might give you a chance to see whats causing the wrinkles.
Kevin
Allworth
First, find a competent RV repair center.
Then remove and replace.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
greende
1slomofo wrote:
I doubt there is still water in there. Taking it off and drying it is not going to "repair" it. That has some water damage - Will need to be replaced to look right again.
Agreed. The backer on that vinyl ceiling is cardboard. As the water dried up, the cardboard wrinkled and that's what you see on the surface of the vinyl. Replacement is the only thing to make it look neat again.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
USAF 1968 - 1972 Viet Nam '71 - '72
1slomofo
-2015 32SAG Eclipse Attitude Toyhauler
-2010 Mosebilt 2-seater Long Travel Sand Car
-2008 GMC Sierra 2500HD Duramax
-2006 Kawasaki Kfx400
-1984 Wife
