โOct-06-2014 10:21 AM
โOct-06-2014 02:21 PM
โOct-06-2014 02:11 PM
salem wrote:
Ed ke6bnl: Do you know who makes those, or what they're called? I'd like to look them up if you do. Sounds like something I'd be interested in.
โOct-06-2014 12:45 PM
Road Runners wrote wrote:
I too carry 1/4 and 1/2 inch squares of plywood to fine tune the landing gear length
โOct-06-2014 12:44 PM
โOct-06-2014 12:11 PM
laknox wrote:
Personally, I level side-side, pull the pins on the landing leg extensions, let 'em hit the ground, then power the legs down until the pins snap back into place. I've never been on a spot so unlevel that I felt I had to shim one side over the other. Any twist to the frame is so minor that I doubt I could even measure it. All I do is to put a spare lego block under the feet to spread the load a bit. (shrug)
Lyle
โOct-06-2014 12:10 PM
Road Runners wrote:
I too carry 1/4 and 1/2 inch squares of plywood to fine tune the landing gear length.
โOct-06-2014 12:04 PM
โOct-06-2014 11:55 AM
โOct-06-2014 11:16 AM
โOct-06-2014 11:13 AM
โOct-06-2014 11:08 AM
โOct-06-2014 10:43 AM
โOct-06-2014 10:38 AM
โOct-06-2014 10:29 AM
