fallonator22's avatar
fallonator22
Sandpiper and Park Cable
Plugged into park cable. Clicked the little green button just like the dude at the RV place told us to so it wouldn't interfere with antenna. Not working. Ideas?
  • Figured it out! As someone posted above, switched to cable and re-scanned channels after turning off antenna booster. Worked on both TV's! Thanks everyone!!
  • I had this same problem with my new wildcat.
    I made sure the amp was off, tv set to cable scanned channels nothing
    ran cable through rear window to tv everything worked.
    took it to the dealer they went all through checking all of the wiring and everything was hooked up correctly.
    Finally they found there was a 50 cent jumper that wasn't installed on the amplifier. they put that on and everything works now.
    are you speaking of the antenna amplifier button? If so, it has to be turned OFF. And then as others mentioned, rescan your TV for cable, not antenna.
  • 1995brave wrote:
    Did you change the TV input to Cable and rescan channels?
    I will try that!
  • More and more cable systems are requiring a box to get even basic cable. Did you ask at the office if the cable was PNP or a box needed
