- mwpjrExplorerYes, they require some attention - but not so much that I'd call it a problem. I spent an hour running a fresh bead of caulk around the seams - which would be a good idea with any new rig. In the end, got the shower we wanted w/ just a little work to make sure of no leaks.
- pronstarExplorerI like our current one-piece shower way better than the "seam" design on our previous RV's shower - the caulk didn't really stick too well in the seams.
- flyinjakeExplorerMookie,
Are you looking for a new trailer also? In my searches I have noticed that some manufacturers use a one piece shower that personally I like. I believe it to be the same or close to the same material used in home showers.
Jake - MookieKatExplorerSlower than I would like....thanks for asking.
- campincandiceExplorerHow's the search going, MookieKat?
- MookieKatExplorerThank you. I thought that might be the case...
- Sturgeon-PhishExplorerYep, I clean the seam out and recaulk ever so often
Jim
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
