jepalmer's avatar
jepalmer
Shower doesn't work
Newbie question
First trip out and the shower has hot and cold water when running off of the pump but nada when running off city water. Sinks work ok in both modes.
Am I missing something ?
Suggestions?
It's a 2008 North Shore (Dutchmen) 31RG
Thanks!
  • h2guy wrote:
    C'mon guys, he said the shower WORKED when using the pump, just not on city water. Head ain't turned off.
    But you'll also see that he was the one that brought up the shower valve being off.
  • C'mon guys, he said the shower WORKED when using the pump, just not on city water. Head ain't turned off.
  • You know, the obvious escapes us sometimes. The pipes that supply the sinks, supply the showerhead too. That valve at the showerhead or grit in aerator.
  • jepalmer wrote:
    Shower head has shut off valve!
    Duh!
    Been there, done that!
  • Do you have everything set to run off the system use or city use? In our unit, we have to choose system use in the docking station to use the pump and city use if using city water. I forgot to change to system use when leaving a rv park once and about 3 hrs down the road we stopped at a rest stop and the pump wouldn't pull in water. It stumped both of us for a little while until I remembered and switched the knobs. I have also forgot to change to city before and had very little water pressure even though it seemed to run well from hydrant. Luckily I remembered before needing the shower. Hope your problem is as simple. We have all had newbie issues before.
