โAug-26-2015 08:57 PM
โSep-04-2015 12:40 PM
Allworth wrote:
I had a bedroom slide that leaked at the lower trim on the outside wall.
Rain ran down the outside of the wall til it hit the trim at the bottom. Went behind the trim, then wicked between the inner and outer floor panels and ran out at the inside rear corner onto the bedroom carpet.
We resealed at the top seams two or three times before we realized that it was the lower area that was letting it in.
Painted the seam with Lanco (brand) elastomeric Roof paint and it has been good for a year now (including some really hard rainstorms). I watch for travel vibration induced cracks in the paint, but have not seen any.
Lanco is available at Home Depot.
โSep-04-2015 09:08 AM
โSep-03-2015 03:31 PM
LOFAT36 wrote:
Well I put 1/4" x 1/2" weather strip on the inside today. Slide's out now and waiting for rain to see if that did the trick.
โSep-03-2015 02:27 PM
โAug-27-2015 06:33 PM
โAug-27-2015 06:24 PM
Learjet wrote:
are you sure its not a window? Had a window issue that caused water on my Bedroom slide.
โAug-27-2015 06:10 PM
โAug-27-2015 03:43 PM
โAug-27-2015 03:10 PM
LOFAT36 wrote:
I like the self stick weather strip idea, as the way water comes in it's usually from the top. Would self stick black foam tape work or would it just soak through the foam and past the adhesive backing ?
โAug-27-2015 03:04 PM
โAug-27-2015 05:20 AM
โAug-26-2015 09:42 PM
LOFAT36 wrote:
So our bedroom slide leaks when it rains hard. 2012 Crossroads Cruiser. I've checked the three seals and all seems to be well, and they have been lubricated since new. It leaks in from the bottom rear of the slide onto the floor above the stairs. I can't see any gaps, what the hell ? Way too far to take it to a dealer. Any ideas ?
